Bale twine connection
Doug
05-31-2002 06:15:24
What is the best way to tie one spool of twine to the next?
JMS/MN
05-31-2002 23:23:47
 Re: bale twine connection in reply to Doug, 05-31-2002 06:15:24
Square knot- not a granny knot.
Jim in michigan
05-31-2002 15:09:26
I use a becket bend or sheet bend ,, make a bight (bend in the rope) pass the other rope through the bight, the over the rope and under itself again and pull it tight.....
JD70Jim
06-01-2002 13:39:23
 Re: Re: bale twine connection in reply to Jim in michigan, 05-31-2002 15:09:26
The OM for my JD 337 specifies "Square knot" for twine and "Sheet Bend" for plastic. It also says the knot needs to be as small as possible in order to pass through the knotters properly.
Duner Wi
05-31-2002 12:28:59
With sisal twine make the first 1/2 of a Sq. knot.
Now bring the ends around like you were th complete the sq. knot but instead push one end of twine into the opposite end for about 3/4 inch.
You might spit on it also if desired .
Makes a very small knot and if made correctly holds as well as a sq. knot. I never tried it with plastic twine.
Duner Wi
05-31-2002 12:23:56
Duner Wi
05-31-2002 12:21:23
Duner Wi
05-31-2002 12:21:04
paul
05-31-2002 08:36:14
Square knot, short ends.
--->Paul
