Agri Five Blade Sharpening ( Removal)
Matt Stockton
06-02-2002 23:25:12
I have an agri fiv that I got as part of a package deal. I have used it for a little over a year and the blades need to be sharpened. I am having difficulty removing the blades for sharpening. Has anyone done this before. I have removed the center nut, but was unable to get the disk and blade combination off the shaft. The bolt and nut on which the blade pivot SEEM inaccessable. I did a fair job with a 4.5" angle grinder, but it was a long hour and a half. I need to know how to remove the blades.
ken
08-15-2002 06:59:24
 Re: Agri Five Blade Sharpening ( Removal) in reply to Matt Stockton, 06-02-2002 23:25:12
The bolt and nut on which the blade pivot SEEM inaccessable. what i did was cut a 3 inch hole directly above the nut, in the back area of the deck. i use an impact to remove the nut and blade, rotate 180 degrees and rattle of the other one. otherwize you have to use a puller on the center nut, not an easy task. i also use the hole to oil the underside.
