Help w/NH66 baler p/u clutch
Bruce
06-06-2002 20:02:02
I have a NH Super 66 baler. The clutch plate and sprocket will not stay engaged. The ends are worn and I need to take them off to fix. The clutch hub which I think is keyed to the shaft will not move. I think that is what caused the other parts to wear. Any suggestions on moving the clutch hub off the shaft. I do not see anything holding it in place and think it should float. Could it be rusted on that tight? The hay is waiting.
Thanks
BFarr
06-07-2002 07:16:42
 Re: Help w/NH66 baler p/u clutch in reply to Bruce, 06-06-2002 20:02:02
I do not have my part book handy but if I remember right, it is rusted that tight. I had the same difficulty years ago and was surprised at how tight it was stuck. Torch heat and oil.
Good luck....and let us know how it turns out
