KUHN Hay Mower
Aggie
06-07-2002 17:14:47
I used the mower all day and the pto popped off and now will not extend back to the tractor's pto. I put a can of WD-40 on it and nothing happened. What do I do?
Thanks!
thurlow
06-08-2002 13:44:04
 Re: KUHN Hay Mower in reply to Aggie, 06-07-2002 17:14:47
When I've had PTO shafts frozen, have had to hook come-a-long on-to shaft, run under tractor to front axle or whatever will line up. Never had one I couldn't pull free.
Mike
06-07-2002 19:50:00
Was it running at the time? Sounds like it was. If so, it may have gotten bent at the "slide" part of the PTO shaft. See if you can "eye ball" it and tell if it's bent.
Just a guess...
Good luck.
Aggie
06-08-2002 18:57:32
 Re: Re: KUHN Hay Mower in reply to Mike, 06-07-2002 19:50:00
I appreciate the advice.
Thanks!
