Bush hog control
Doug
06-10-2002 20:49:35
I was bush hogging today and am still having an on going problem that I thought one of you fellas could help with. I have AC D14 with a 5' Ford bush hog, the type with a single wheel in back, mounted on a 3 point hitch. As I am cutting the bush hog will tend to sway from one side to the other, does not stay directly behind the tractor. It will go to either side but tends to drift to the right side. I played with the adjustments on the 3 point to try to raise and lower one side or the other, but still the same problem. Anyone have any thoughts on correcting this problem, I don't seem to remember this problem with a two wheel style bush hog? All input is welcomed.
Thanks
Doug
Bob - KS
06-11-2002 07:49:35
 Re: Bush hog control in reply to Doug, 06-10-2002 20:49:35
if the sway chains are not adjustable on your tractor, a stabilizer arm or link will accomplish the same thing. I'm not familiar with the two wheeled variety of rotary cutter, but all the single wheeled variety I've hooked to don't lead well unless you tie them down a bit. They have a mind of their own.
BB
06-11-2002 04:17:50
You need to adjust your sway chains to limit the side movement. I tighten mine to where there is just a slight amount of movement allowed.
