Anybody have experience with Case 220 baler?
Barry Small
06-12-2002 01:03:33
I was looking at tractors yesterday when I ran across an old 220 Case baler sitting on the back of a dealers lot. It was a trade in on a newer baler. The owner broke a needle, and needed a baler quicker than he could fix it. It is in pretty good cosmetic shape for a baler that old, and it comes with a new set of needles. The owner baled over 1500 bales with it this season before the breakdown. I know Case tractors but have never used a Case baler before. Any info would be greatly appreciated.
Barry
LB
06-17-2002 22:45:44
 Re: Anybody have experience with Case 220 baler? in reply to Barry Small, 06-12-2002 01:03:33
I have a 200 with a bale launcher. The baler itself has done a good job for me if I use good dry twin that hasn't gotten wet. The bale launcher broke a spring that resets the clutch for the launcher. Looks like alot of work to replace with an original spring as it's coiled around a shaft. So I hooked a piece of roller chain around the shaft and a straight coil spring on the other end hooked under the baler. Works as good as new now. This is my back up baler to my JD 336.
scooterhead
06-13-2002 04:55:11
I have a 330 and it is a fine baler . Everyone warned me not to get it but it came in a package deal . I`ve always been a NH man and was suprised with the case , it dose a good job . I may have the one good one I dont know . If this baler is not operating you may want to stay away from it , somthing was the cause of the breakdown and if your not a baler man you may spend alot of time cussin and not much time balin . It aint no fun workin on a baler out in the hot sun !!!!
Barry Small
06-13-2002 10:56:24
 Re: Re: Anybody have experience with Case 220 baler? in reply to scooterhead , 06-13-2002 04:55:11
The baler got out of time causing the needle to break. These balers, are supposed to be easy to reset,I've just never done it, and never used a Case at all. It's just for show but I want it to work.
Thanks
Barry
sammy the RED
06-13-2002 00:11:07
Most of them are junk.
Look for a good used New Holland or John Deere baler.
Barry Small
06-13-2002 10:51:26
 Re: Re: Anybody have experience with Case 220 baler? in reply to sammy the RED, 06-13-2002 00:11:07
I'm not looking for a baler to use hard, I just want it to work. My brother has a good New Holland square baler, but round bales are about all we ever put up. I want it to go with my Case tractors so I can demonstrate a Case rig at the shows.
Thanks,
Barry
Barry Small
06-13-2002 10:47:48
Thanks,
Barry
Loren
06-12-2002 17:09:59
I'm running a 133 now, and with the amount of trouble I've been having I'd guess I know it pretty good. I have no idea how close it is to the 220 though. Might that dealer have a line on the knotters for mine? I need at least one for a spare do to unmentioned circumstances. Loren
Barry Small
06-12-2002 22:24:00
 Re: Re: Anybody have experience with Case 220 baler? in reply to Loren, 06-12-2002 17:09:59
The 133 is older than the 220, being built in 1957,& 58. The 220 wasn't built until 1965, and later. The dealer I'm working with isn't a factory dealer, he only has the needles because the farmer who traded in the baler found them later and brought them in. Sorry
Barry
Loren
06-12-2002 17:09:26
