I need disc blades!!
Carl c
06-14-2002 09:19:51
Where is the best/cheapest place, on the the net/or anywhere to buy disc blades. I am restoring an old ...very old Roderick Lean disc and I need to replace all 24 blades. I need either 16" or 18" blades with a 1" square hole in the center. Please help. Thanks.
Ultradog MN
06-14-2002 12:04:09
 Re: I need disc blades!! in reply to Carl c, 06-14-2002 09:19:51
If you're anywhere near Minneapolis MN I know an older guy that has about a hundred used disc blades. I bought 2 older 3 pt discs from him last spring and he threw in several extra blades. He had a large pile of them in his barn.
Otherwise I'd try shoupparts.com or one of the big stores like TSC, CT or Fleet Farm.
Good luck.
JMS/MN
06-15-2002 09:45:37
 Re: Re: I need disc blades!! in reply to Ultradog MN, 06-14-2002 12:04:09
Hey Ultradog- your first eleven words scared me- then I realized I don't have any used blades!
Ultradog MN
06-16-2002 13:08:02
 Re: Re: Re: I need disc blades!! in reply to JMS/MN, 06-15-2002 09:45:37
Heh Heh
Sorry Jim
But then again I wouldn't have said you were older since I thought we were pretty close to the same age.
I do know a fellow who has a couple of grain drills though...
ShepFL
06-14-2002 21:40:09
Carl -
Ultradog MN offers an attractive alternative. In the event it not feasible or you cannot find the sizes you need (remember the blades should be matched in axle and OD size) then check out link below. This is what I found when I was replacing disks on my 10' IHC #37 disk.
FWIW,
ShepFL
