ok. i purchased a wheel rake when my old bar rake bit the dust and i could not afford another one. it raked great,,different, but great. you have to plan your raking directions with a wheeled rake. right hand turns are a no-no because you loose the raking action if you turn moderately to the right. if you don't have good stablizers on your 3 pt hitch, you will loose raking effect when the rake shifts to the right. they tend to twist stalkie material or vines into a rope that will pull into some bailors to rapidly and cause cloging. they rake every thing (leaves, rocks, litter) while bar rakes will shed and not windrow a lot of the same. after almost two decades of use on my 5 wheel rake, i purchased a trailor type double M & W 10 wheel rake. the double Vee allows me to combine three passes of my haybine into one windrow and cuts my raking time almost in half. the trailor is more stable than the 3 pt hitch double rake and is alot, a whole lot easier to hitch to. you can't get into some tight spots with the trailor but thats a trade off i was willing to concede. the M & W is alot better made than anything close to its price (mine was $3000) and has one feature the other rakes don't have. the m & W folds forward and up. this feature allows you to slightly fold the rakes forward creating a larger opening at the rear.whenyou get into heavy hay, you can spread the opening and allow the clog of hay to pass through without stopping like you would with other models (you need double acting hydraulics to operate the M & W). since it rakes from the left and right,tight turns in either directions will sacrifice raking action. i usually make the turns anyway and then as a finish, rake across the ends of the windrows to repair the mess. i have to admit the whole rigg seams a little rickey on rough land so i'm really glad i didn't purchase the lighter made models that John deere and others put their names on. i waited four years to purchase the double rake and did a lot of studing before hand. i put up between 150 and 200 tons of fescue a year (not this dry year) single handed.i just wished i had purchased it years ago. sorry for being so long winded.
