#68 New Holland Baler
Jack Carson
06-21-2002 17:56:13
I have problems with bale size-there is not enough hay on left side-the string is looser than right side and wants to pull off. I adjusted tines but didn't seem to help and doubled windrows etc. It ties great but can't handle bales in barn. Would appreciate any suggestions
thank you.
lotus86
07-29-2005 21:15:07
 Re: #68 New Holland Baler in reply to Jack Carson, 06-21-2002 17:56:13
I tend to agree with the comment concerning the sharpness and alignment of the blades. Give that a try and see how it works out.
I recently bought a New Holland 68 and the blades were separated by almost 1/2 inch and had bales like you mentioned. Re-alignment significantly improved the quality of the bale.
08-21-2004 11:05:48
With the feeder back in the rearmost position bales will tend to have more material in the right side and with the feeder back forward, the bales will generally have more material in the left side. Too much hay in the right side of the bale also is caused by left feeder tines too far toward the right end of the tine bar.
Black Land Farmer
06-12-2004 22:47:53
You should try a John Deere bailer next time !!!!
Better luck next time
RickB.
06-22-2002 14:23:16
You say you adjusted the feeder fork tines. Did you adjust them to the right? Moving them to the right is the proper adjustment for a loose fill of the left side of the chamber.
Scott
06-21-2002 18:15:56
There is too much clearance between your slicing knives and it pulls on the hay instead of cutting it clean, you must adjust the plunger rail track over to make the plunger within .010-.020 of the stationary knife or the wood rails need replaced, sharpen the knives while working there.
