Blades
Charles W Story
06-24-2002 16:43:57
Need a set of blades for my sidewinder model 66 bushhog. When I acquired this hog it had been used very little and shed kept. Previous owner(elderly gentleman) removed blades several years back to be resharpened and that's all he can remember. He said if anything was wrong with hog bring it back. Anyone know what type/size blade I need or can point me in right direction. All help appreciated.
PCC-AL
06-24-2002 18:24:39
 Re: Blades in reply to Charles W Story, 06-24-2002 16:43:57
Hi Charles,
The easiest way is to contact your local Bushog dealer, but mine is about 35 miles away. Yours may be some distance off also.
Next I would suggest that you measure the size of the bolt hole in the spindle under the deck. Also measure the distance from the center of the bolt hole to the nearest edge of the deck that new blades will contact. With these measurements you may be able to find blades to fit from a local farm supply or tractor dealer. Good luck.
Thanks
06-25-2002 04:56:47
 Re: Re: Blades in reply to PCC-AL, 06-24-2002 18:24:39
Appreciate the help.
