346 Baler that won't tie on one side
Jack
06-28-2002 13:32:10
Got 346 that misses every now and then on the right side.It is getting worn but don't think that is my problem.It will miss two and then maybe start tying by itself and sometimes you have to go back and tie off your wire and start over.Is it my needle not picking up the wire or is it a tension problem ? My needles are wore a bit and the guides above the spool on the end of needle is worn, but not any worse than the other side.It tied good in wet hay but the dryer it got it started to missing on right side.Can anyone help!!!
EARL
06-29-2002 09:04:14
 Re: 346 Baler that won't tie on one side in reply to Jack, 06-28-2002 13:32:10
DO YOU HAVE A BOOK ON THE BALER TOO BE ABLE TOO CHECK ALL OF YOUR ADJUSTMENTS ALSO IS YOUR KNIFES BEEN SHARPEND YOUR HOLDERS MAYBE OUT OF WHACK YOUR TWISTER HOOKS MIGHT BE OFF AND SOMETIMES A GOOD KLEENING WITH A POWER WASHER AND LOTS OF GREAS & OIL WILL MAKE A DIFFERANCE WORKS FOR ME ON MY MASSY 126 WIRE TIE
Jack
06-29-2002 21:44:25
 Re: Re: 346 Baler that won't tie on one side in reply to EARL, 06-29-2002 09:04:14
Thanks guys I think I got it fixed went 100 bale and missed 2.Thats sounds better than make 5 skip 2.Think needle was out of alignment. It looked ok without hay but worn enough to push to the side with a load on it.HEY guys Thank You very much.At least ya'll got me thinking again.Jack
EARL
06-29-2002 09:03:13
Jerry D in NC
06-28-2002 17:17:55
Jack,
I am confused as to whether this is a twine baler that ties or a wire baler that twists? If it is twine then we need to know a little more about the knot and what is going on. If it is a wire twister then Lord knows somebody that knows what you are talking about will need to answer you.
Jack
06-28-2002 18:08:26
 Re: Re: 346 Baler that won't tie on one side in reply to Jerry D in NC, 06-28-2002 17:17:55
Sorry guys this is a wire tie baler
Jerry D in NC
06-28-2002 18:26:34
 Re: Re: Re: 346 Baler that won't tie on one side in reply to Jack, 06-28-2002 18:08:26
OK I officially admit that I am more clueless than usual. I can not be of help. I don't even have a manual on a wire tie much less experience. Sorry
