Broken Sears Disc
Jim W.
07-07-2002 13:44:47
I have a 6' 3pt. disc the tag says Sears and Co. Model 9091044. It has a broken casting on the rear gang and two broken disc blade. The casting number is D4075. I would like to fix this disc but have been unable to find parts locally. If anybody out there has or knows where to get them I would appreciate your help. Used parts or a parts disc would be fine. Thanks Jim W.
JMS/MN
07-08-2002 22:43:35
 Re: Broken Sears Disc in reply to Jim W., 07-07-2002 13:44:47
If you have all of the broken cast parts, any good welding shop should be able to weld them for you. Disc blades do not weld well- they just break again- buy new blades.
Ultradog MN
07-07-2002 20:33:29
Hey Jim,
By broken casting I am assuming you are talking about one of the castings for the bearings?
There are some bearings available at a couple of places.
I would try shoupparts.com or else try the link below.
Agri-supply has their entire catalogue online but you need Acrobat Reader to view it because it's in .pdf form.
If you don't have Adobe Acrobat Reader it is worth having. It is free - you can dl it off that link below.
Otherwise you can give agri-supply your snail mail address and they will mail you a catalogue for free.
Be prepared for sticker shock when you are playing with these old disc parts.
PS. The disc wheels or blades are readily available at any place like Fleet Farm, CT, TSC,
or even most tractor/implement dealers.
Let us know if you find what you're looking for.
Good luck.
