Front end loader
PJ
04-06-1999 22:44:53
I got ahold of this old front end loader. Don't know much about em though. Needs a bit of work, but I already got it cleaned up and painted ford grey. Came off an ford 200 and I will put on ford 801. The guy said it is an industial loader with pump and double acting cylinders. Now its time to go thru hydaulics, but I have some questions
#1 - the old valve reads parker on it. can I replace with two spool valve available at Rual king or Tractor Supply? (what should I beware of) all hoses and lines need replacing.
#2 - Shoul'dt I clean out the resavior (oops) and how.
#3 - Where can I get parts and info on this loader. The guy thought it was a Ford made loader but I think it's Parker Wish me luck, PJ
Wayne
04-07-1999 03:00:34
 Re: Front end loader in reply to PJ, 04-06-1999 22:44:53
The TSC valves would work if similar. Run a little fuel in the res. to wash it out. Install a filter between the res. and pump. this can save your pump bg$$$$$.
PJ
04-06-1999 22:46:50
ps, correction, came off ford 2000
Tim(nj)
04-07-1999 07:21:46
 Re: Re: Front end loader in reply to PJ, 04-06-1999 22:46:50
Parker-Hannefin is a hydraulic component manufacturer. They made your valve, and possibly your pump, but not the loader.
Melvin St.John
06-02-1999 03:48:05
 Re: Re: Re: Front end loader in reply to Tim(nj), 04-07-1999 07:21:46
We are looking for a used front end loader for a John Deere A or B. If you have knowledge of one
we would appreciate your response as to location and cost. Thank you for your time.
