General plow question
Shawn
07-08-2002 13:40:34
Just bought a 3 bottom plow and heard that there is a spray to put on the mold boards instead of greasing it everytime. Just wondering if anyone new if this is true and whats it called. Thanks
signman
07-09-2002 11:36:11
 Re: general plow question in reply to Shawn, 07-08-2002 13:40:34
I think the product you are speaking of is called Plow Coat. It is a heavy oil. Of course good thick waist oil will do the same thing. The John Deere product is a fair protectant if the plow is used regularly but for long term over 1 year outside storage it will rust through. Slip plate is a paint and on our pushy loam soils paint on plow bottoms is disastrous. it takes many acres to scour a plow in our soil so any type of paint is a frustration. Yet in other areas I know they never even grease or oil their bottoms. Their sandy clay soils will clean the rust right off and go to work. Good Luck
JT
07-08-2002 22:30:51
John Deere sells a soft black paint specifically for this purpose. Spray it on and it protects the moldboard from rust and then it comes off just like grease when you go back to the field.
I have never tried using slipplate on moldboards I always figured a well polished bottom worked best.
HTH
JT
rednekelmo
07-08-2002 15:34:29
yup go with slip-plate it's great for plow bottoms gravitybed wagons or anywhere you wany things to slip and not rust when in storage
rednekelmo
07-08-2002 15:32:57
Tim W
07-08-2002 15:05:55
I use a product called Slip-Plate. Last i got was from TSC last year. I get it in a quart, but I think they sell it in a spray. Might also try Grainger
