: : : Wondering if there is a planter that will plant both types of seed. Would need to be an older model due to lack of funds!! : : I suppose you could use a plate type corn planter. We had a late 1960's vintage International 4-row that we planted corn and beans with. It was a plate-type, not air planter. One year we experimented with sunflowers in an 18 acre patch, and used sunfower plates (plastic) that had a spacer ring under it because the plate was thinner than the normal corn or bean plates. The spacer ring had a hole which allowed the seed to drop through into the chute. If you had a plate that would handle the pumpkin seeds, you might be able to block some holes and space the pumpkins out some. I've seen bean plates for this type of planter that had some rather large holes them. Perhaps a plate of that type could have some holes filled with epoxy or brazed shut, and let the remaining holes drop pumpkin seeds a few at at time in "hills" a few feet apart. You could put pumpkin seed in one box, and corn in the others. Interesting idea, I'd like to know how it turns out if you try it! : : My dad told me one time that when he was growing up, they planted a lot of pumpkins with the corn. He said grandpa would just throw a handful of pumpkin seed into the hoppers of the corn planter. This was back in the 1930's or so and they were using a horse-drawn, plate type, two row corn planter. Two years ago I decided to try planting pumpkins like this since I figured the plants would spread well after the last run through with the cultivator and would give me some extra pumpkins to sell. I filled the hoppers about half full with corn, mixed in a handful of pumpkin seed and topped off with more corn. The outside rows did real well, but that was it. The pumpkins in the inside rows never got enough sun to grow and only produced a few small pumpkins. Dad said that of course when they planted it was all check row corn! I could understand it then since the extra distance between corn in the row would give the pumpkins the room they need. : I still haven't figured out which was worse, picking corn by hand while walking through the pumpkin vines or picking pumpkins and packing them through the corn rows! I DON'T HAVE ANY EXPERIENCE IN IT, BUT I've been told that in areas where there are lots of racoons, it was common to plant pumpkins in the perimeter of a corn field. Apparently the theory is that the spines on the pumkin vines discouraged the racoons from harvesting the field. As I understand it, only the outside edges of the corn field were interplanted with the pumkins, not the whole field.
