Jd plow with cast wheel
36 A
07-09-2002 19:15:19
A frend of mine just got a three bottom plowwith a cast land wheel.The trip has a hub like a wagon wheel hub then a big cast center with spokes then the 21" rim .the plow has 55 a--cant read the rest.any info would be great.thanks
Jerry S
07-10-2002 10:46:36
 Re: jd plow with cast wheel in reply to 36 A, 07-09-2002 19:15:19
The best thing you can do to ID it is to read the beam numbers on the plow. Green Magazine is doing a several part series on plows and it would likely have all the info needed to tell what it is and what years it may have been built. You could repost with that and someone could look it up for you either here or on the JD board.
Jerry S
07-10-2002 10:41:32
