Drag Plow Experts J.D. Plows???
FARMMAN
07-12-2002 10:59:19
I wrote in a couple months ago about my plows that tripped when I took out a grease cap ( if anyone remembers.) Well I took it apart and is fixed. When I got it apart I found yellow and green paint. John Deere? Can't send a picture in but the wheels are spoked, 2 bottom 14" plows with 2 adjustment leavers. Where should I be looking for numbers so you guys can give me some better info. What do you need?
Andy Yost
07-23-2002 12:57:14
 Re: Drag Plow Experts J.D. Plows??? in reply to FARMMAN, 07-12-2002 10:59:19
That sounds like a deere. My uncle Merle has a 2-bottom JD that has the spoked wheels and two levers like you describe. Seems to me there is some kind of writing molded into the beams.
Bob Collins
07-13-2002 18:15:22
If the words John Deere are stamped into the top of the beams, there should be a number following the words, this is the best starting place, if it is a truss frame plow with bar stock beams, look for casting numbers wherever you can find them and tell us the location and the number. Bob
