Bent wheel disc gang axle.
Ben Snead
07-18-2002 07:38:26
I've got an old four gang, wheel disc that nobody can identify. It's painted Ford blue but no I.D. plate or stamped numbers. (Parts have been very difficult to find). It has a bent axle on the right rear gang (about 45 degrees). The axle (round) is bent at a taper where the outside bearing is located. Anybody had any luck straightening axles or should I get one machined?
Richard
07-18-2002 14:30:36
 Re: Bent wheel disc gang axle. in reply to Ben Snead, 07-18-2002 07:38:26
Put it on the anvil and beat with sledge. Worked fine for me on an old IH disc with a sharp bend in a gang axle.
ShepFL
07-18-2002 13:23:58
My experience has been they bust. I bent some plow beams while back. Took them to a truck stop with heavy duty press. They straightened them out by applying pressure right at the high point.
I am sure they are somewhat weakened but how often will I bend them? Not often as my knees took nearly a week to heal!!
ShepFL :)
ShepFL
07-18-2002 13:21:47
ShepFL :)
JMS/MN
07-18-2002 10:05:13
If you were lucky enough to bend it instead of breaking it, just take it to a shop and have it straightened- might even do it cold. Otherwise, anyone with a torch can heat it and bend it straight. Usually they break.
Ben Snead
07-18-2002 10:22:07
 Re: Re: Bent wheel disc gang axle. in reply to JMS/MN, 07-18-2002 10:05:13
Thanks for all the good advice boys...its nice of you all to share your experience. Best regards, Ben
Ultradog MN
07-18-2002 09:51:18
I believe most any welder could straighten it if he heated it up first with a torch. It doesn't have to be perfectly straight because they turn so slowly.
I would try that before buying new.
For other parts as Paul says try shoupparts.com
or try agri-supply.com. Agri-supply will send you a free catalogue or you can download it in .pdf format if you have adobe acrobat reader software installed on your computer. Adobe is free and there is a link to get it agri-supply.
The link to the pages for disc parts is below.
paul
07-18-2002 09:25:37
Wow. They normally are hardened, so rarely bend - they break. I think it will get so weak by the time you straighten it.....
Have you checked Shoup, they handle all kinds of disk parts, plus custom make disk shafts. A round one shouldn't be too bad $$$.
--->Paul
Dan Davis
07-18-2002 20:03:28
 Re: Re: Bent wheel disc gang axle. in reply to paul, 07-18-2002 09:25:37
I saw a used Burch? sp? disk at a local dealer. Looked like original blue paint. Thought it was Ford at first. LOL.
