Ford 4000 with blade
don N.C
07-18-2002 18:04:53
I recently bought a 7 foot blade that weights around 280 LBS and noticed how much better it does with my weight on the blade when scaping hard ground so i got two suitcase weights at 100lbs a piece but they were broke where they hang at. so i need to mount them on the blade on the side so they do not stick over the blade so that it can be rotated. any one have any ideas thanks in advance DON
paul
07-19-2002 09:13:05
 Re: ford 4000 with blade in reply to don N.C, 07-18-2002 18:04:53
I'd put a bracket or box on the frame over the pivot area, leave the blade to jump around on it's own.
--->Paul
Jhill
07-19-2002 07:05:37
Could you drill a hole thru them and bot them flat on top of the upper framework.
