How to hook-up Deere 360 sickle mower?
RayP(MI)
07-19-2002 05:57:51
Am trying to use a Deere 360 sickle bar mower on a Farmall 200 with 2pt to 3pt conversion. Arms and everything fit OK, but there's an arm sticking out the front of the mower that sticks forward between the 3pt hitch that apparently attaches to the tractor somewhere by a chain assembly to work the lift mechanism. Also has a chain attached to same bracket that is connected to frame of mower. Where does this chain thingy connect to tractor? Mower was last used on MF 85 which is entirely different from the Farmall! (Grandpa says he hasn't used it in 10 years, and can't remember how it hooked up!)
Correction - Model 350 mower!
07-19-2002 06:20:19
 Re: How to hook-up Deere 360 sickle mower? in reply to RayP(MI), 07-19-2002 05:57:51
Son tells me it is a model 350 mower not 360! (RAY)
JohnnyB
07-19-2002 14:16:02
 Re: Re: How to hook-up Deere 360 sickle mower? in reply to Correction - Model 350 mower!, 07-19-2002 06:20:19
The chain should hook or bolt into the hole in the end of the drawbar, this gives a leverage advantage to pick the mower high into the air.
RayP(MI)
07-19-2002 17:45:40
 Re: Re: Re: How to hook-up Deere 360 sickle mower? in reply to JohnnyB, 07-19-2002 14:16:02
No drawbar on a Farmall 200! comes off 2pt hitch when you put the 3pt arms on! Looks like I gotta build something.
