IH Corn Planter Model#
Marvin(MN)
07-19-2002 21:37:58
Just picked up a 4 row IH planter and need the model# so I can get the manual. Don't have pic yet but here are a couple part #s 625198 R1 and 671391 R1.It has disc openers and hyd. lift.All help will be appreicated. Thanks in advance. Marvin
john d
07-21-2002 20:24:23
 Re: IH Corn Planter Model# in reply to Marvin(MN), 07-19-2002 21:37:58
A little more description might help....
What about seed boxes and fertilizer bins? Metal or fiberglass? What do the press-wheels behind the runners look like? Rubber-tired, or metal? Is the main "frame" of the planter a pipe with heavy plate welded to the ends to form the basic structure, or is it all angle iron?
If it's got fiberglass bins and seed boxes, rubber-tired press wheels, and a heavy pipe frame, it could well be a model #56.
Marvin(MN)
07-21-2002 21:26:20
 Re: Re: IH Corn Planter Model# in reply to john d, 07-21-2002 20:24:23
John: Thanks for the reply.The fert. boxes are fiberglass and the seed boxes are galvanized steel. The frame is angle iron. It also has Gandy boxes (2)and rubber tired press wheels. Also has double disc openers. Hopes this helps.
Marvin
Marvin(MN)
07-21-2002 21:24:17
Marvin
john d
07-22-2002 12:22:21
 Re: Re: Re: IH Corn Planter Model# in reply to Marvin(MN), 07-21-2002 21:24:17
Post a picture, and I'll bet someone can ID the thing. From your description, I'd say it was a late 1950s - to mid 1960's model.
