605 vermer round bailer
STEVE
07-20-2002 13:15:43
ok guy, help me out here, there is a vermer round bailer in the paper here in town, for 250.00 or make offer, i dont know anything about these round bailers, are they good or bad, and can u still get parts for them,,,i have been looking for one for awhile and this is defenitly in my price range, any info would be apreciated,,,,thx steve
ken
07-20-2002 20:03:36
 Re: 605 vermer round bailer in reply to STEVE, 07-20-2002 13:15:43
If it's a closed throat baler i don't think you would be happy with it.I have run both kinds and the open throat is the best choice. With the open thraot you dump a bale and go on to the next one, with the closed throat you dump a bale and spend the next ten minutes getting the next one started unless conditions are perfect.But for the price you may can take your time. It's not as bad on an air conditioned tractor that i don't have.Be sure to check the belts to see if ther in any good condition.
Craig MO
07-20-2002 18:51:06
Parts are still available and Vermeer makes a good baler. The baler you are looking at must be a 605C or earlier. These don't make near as tight a bale and are not open throat. They will bale hay though and do a good job for you unless you put up quite a bit of hay then I wouldn't want anything older than an F series 605.
paul
07-20-2002 15:39:19
There is a letter designation after the number - this shows the model/age of the machine. For $250, you must be looking at a 605A or 605B that's well used? These were not open throat designs, and do not feed cornstalks, or hay, as well. They don't start bales as well. Etc.
But, this is based on what I have read over the years. Like you, I'm looking to buy a round baler as well...
--->PAul
Mike
07-21-2002 16:54:54
 Re: Re: 605 vermer round bailer in reply to paul, 07-20-2002 15:39:19
Could someone explain further the open vs. closed throat thing. Rould balers are new to me also and would like to be able to tell the difference.
Thanks.
thurlow
07-21-2002 20:14:00
 Re: Re: Re: 605 vermer round bailer in reply to Mike, 07-21-2002 16:54:54
Closed-throat Vermeer had 2 fixed press rolls just behind pick-up reel. Everything that went into baler had to go between them. When hay conditions were perfect (literally), I've baled 20 bales (5 ft x 6 ft) per hour many a time. I've also spent 2 or 3 hours at a time trying to unchoke the thing when things weren't right. Open throat (not sure when they began, I know "F" series is) does not have press rolls. Will feed most anything pick-up reel will pick up. Used to have a "C" model (closed throat); if you're not looking to bale a lot of hay, you'd probably be pleased with it. I would be a little leary of anything earlier (with flat belt in bottom for roll to turn on.
