3-POINT-HITCH FIX'INS
THE WINO
07-23-2002 08:48:33
HELLO EVERYONE, I RESENTLY BOUGHT A 1955 MINN-MOLINE"UB" LP/GAS TRACTOR. IT HAS SOME HYDROLIC PARTS ONBOARD.THE HOSES RUN FROM THE PUMP TO THE REAR OF THE TRACTOR.ALSO THE HYD.SLAVE CYLINDER IS ON THE RIGHT BY THE TWO BRAKE PEDALS. NO LINES ATTACHED!! WHERE DO THEY ATTACHED? THE CROSS BAR IS CONNECTED-- BUT WHAT GOES ON IT TO ATTACHS THE 3-POINT HITCH.WHAT DO I NEED TO USE THE HYDROLICS+3-POINT HITCH?? THANK YOU,THE WINO..... .....PS:DOES THE HYDROLIC SYSTEM USE MOTOR OIL FROM THE ENGINE?BECAUSE I SEE A LINE COMING OUT OF THE BLOCK TO THE HYD. TANK.
Jerry D in NC
07-24-2002 04:30:09
 Re: 3-POINT-HITCH FIX'INS in reply to THE WINO, 07-23-2002 08:48:33
I have no idea about an answer to your question but if you have not already tried the Minn Moline forum listed at the top of this page, I would try there. You will run into folks that know the MM better than the general audience here on the Implement Forum
