Broken bush hog
Chuck S
07-27-2002 14:53:25
I posted a few days ago asking for advice on broken bushhog. I have tried much and know more.
My bushhog is a Howse, 5 foot. It is leaking oil from the gear box. The gear box bolts are loose which I was able to tighten (and stripped one of the nuts in the process.) I will know tomorrow if the tight bolts fixed the leak. From what I have read from your posts - probably not as the gear box is self=contained. Probably a bad seal that needs to be replaced. Which will require that the stumpjumper come off.
I do think the right answer is to get the stump jumper off and replace the stripped nuts and include heavy duty lock washers and locktite.
How do I get the stump jumper off? I have the crown nut off and have hit, whacked, pulled, etc. and it doesn't move at all.
This is a Howse hog (bought used for $150 - never owned one before so I was clueless). AFter reading the number of comments saying HOwse is junk, I guess I blew it. But, I would like to make it limp along for at least a year. I only cut grass on a 5 acres field monthly so ...
Ideas please?
Chuck
Burrhead
07-28-2002 07:33:51
 Re: broken bush hog in reply to Chuck S, 07-27-2002 14:53:25
These fellers are right on about the Howse being junk. I have some and they are big time junk.
I would'nt worry about the bottom seal leaking. If you put a new seal in the thing will be leaking again in a day or 2 if it even stops leaking at all. Most times even a new Howse won't hold gear oil anyway. Just take the top gear box plug out and pump the box full of grease.
Every time you start to use the hog take the plug out and pump it full of grease again til you get the gearbox filled with grease.
I've got a 6' Howse I bought new that I went thru all the trouble to put new seals in twice before it was a month old and did'nt get the leak stopped. I've used it about 8 years on the pure grease and it does fine and does'nt leak.
The gearbox runs cooler and does'nt do all the Howse whine with grease in it, and with pure grease it will eventually stop leaking
WILL
07-27-2002 20:48:06
OK IF YOU WANT THE STUMP JUMPER OFF I DONE THIS BEFORE MORE THAN ONCE! CUT A HOLE IN THE STUMP JUMPER ON BOTH SIDES OF SHAFT AND THEN PUT A BOLT IN THE HOLE THAT YOU CUT OUT. TAKE A 3 X 3 TUBING 1/4INCH THICK DRILL 2 HOLES TO MATCH THE HOLES IN THE JUMPER BOLT IT TO JUMPER AND PUT A 20 TON JACK ON TUBING AND THE SHAFT WITH THE NUT ON THE SHAFT USE A LONG HANDLE IN JACK AND GO TO IT!
Craig MO
07-27-2002 17:15:07
The only way I have been able to get the stump jumpers off is to drive wedges under the edge of the stump jumper and then hit shaft with a maul but be sure and install nut flush with end of shaft to protect threads. If you don,t mind cutting a hole in the top deck you can do this and insert a shaft in the hole to remove stump jumper. If you are not sure the seal is leaking try putting pour grease in the gear box. It provides good lubrication as it gets thinner when hot to keep bearings lubed up. They use this type in several disc mower gear boxes.
RickB.
07-27-2002 15:21:58
If you get to replacing the gearbox mount bolts, use new nuts and bolts with high strength loctite and forget the lock washers. Using self-locking nuts is a great idea, but may be a bear to install unless you are sucessful in removing the stump jumper. Don't expect replacing/tightening these bolts to affect the leak. Using grease is a good plan for a 'beater' cutter's box.
Try this
07-27-2002 15:05:31
Don't take the stump jumper off until you see if you can stop the leak. Tighten down all the gear box bolts and drain the oil in the box. Refill with the box with grease instead of oil. Just pump grease from your greasegun in it.The heavy grease may not leak as the oil did.
