Are there any PTO combines that work with an 8N?
Ed Stembridge
07-29-2002 15:50:20
I'm new to all of this, and am trying to find out if there are any older small PTO combines that I can power with my Ford 8N...
I have 15.5 acres, of which about 11 is tilled. We currently have oats & alfalfa (mostly for hay, but the wife wants me to harvest some of the oats), and about 1/2 acre of wheat.
Thanks for any pointers on whether I can use the 8N for this or not.
es
larry va.
10-15-2002 18:59:11
 Re: Are there any PTO combines that work with an 8N? in reply to Ed Stembridge, 07-29-2002 15:50:20
I.H.made a one row for a C farmall it would be like looking for a needle in a hay stack.
Leroy
08-01-2002 06:08:57
The 8N noes not have enough power for a 5' on pto, you would need on with a motor, an NAA has half again as much power and will pull a 5' OK
Find you an 11-A John Deere
07-30-2002 18:46:11
tim[in]
07-30-2002 11:01:45
an allis allcrop 60 or 66 should work just fine. also ford had a combine i belive was made by wood bros. that work good with an 8n. my neighbor used to custom cut quite a bit around here with a naa and an all crop. most big farmers dont want to be bother with small patches . and when your stuff needs combining , so does theres. so guess who is first priority! i dont know if you would be better off with one that had an engine instead of pto . but if nessecary you can always adapt. the amish put the engines on carts and pull the combine behind them. or you can always buy a small E or K gleaner combine or a 35 massey . the gleaner will be the easiest to find parts for. plus an E or a K will go fairly cheap at most auctions. i have a 72 all crop i pull with an allis D 17
Ed Stembridge
07-30-2002 14:49:05
 Re: Re: Are there any PTO combines that work with an 8N? in reply to tim[in], 07-30-2002 11:01:45
Thanks everyone - this is really great info, and now I have a better feel for what to look for.
I'll probably end up paying someone to harvest for me this year (if I can find anyone willing to do the small amount I have), and can then start looking for something to purchase for next year.
es
Ed Stembridge
07-30-2002 14:48:05
es
Leroy
07-30-2002 06:16:16
Both the AC 40 & IHC 42 are in that class, both built only a couple of years in the early forties, if you find one in working condition, a five year project, expect to pay double for it as to what your tractor is worth. Multi thousand Dollars.
Just_an_Idiot
07-29-2002 19:54:49
hire someone to combine it for you, about $20 an acre. You will be way farther ahead, trust me. Combines are a high maintenace item and fro your amount it dont make sense, been there done that.
just my opinion but I'm JUST AN IDIOT
dcv
07-31-2002 19:29:27
 Re: Re: Are there any PTO combines that work with an 8N? in reply to Just_an_Idiot, 07-29-2002 19:54:49
That depends on how much you have to combine, and where you are. We only have a very few custom operators and they charge $30-$40. per acre with a 30 acre minimum. Most of our growers will have no more than 20 acres so it gets mighty expensive mighty quick (Central Kentucky). The $1000 for custom harvest will buy a good PTO combine.
Brandon
07-29-2002 18:36:13
Your 8N should be able to pull a model 40 All Crop Allis Chalmers combine. The hardest part will be finding one. Good luck Brandon
Ed Stembridge
07-30-2002 04:00:58
 Re: Re: Are there any PTO combines that work with an 8N? in reply to Brandon, 07-29-2002 18:36:13
Thanks for the tip - that at least gives me something to research and look for now..
es
