Chris, NI Pitman dimensions
Errin OH
08-05-2002 09:03:36
Chris, These were taken form my broken pitman. Its painted green and have a good felling its factory or a factory replacement. The mower I have was well taken care of and has all original parts (as far as I can tell). I also have an original kicker board and can provide those dimensions as well. I suggest that you mount the rotator end and mark the first hole on the sickle just so you get the timimg correct. Also, there is a rivit (sickle end) centered between the first and second hole going from top to bottom (holes are front to back) I beleive it is to prevent spliting of the pitman.
Pittman arm dimensions for New Idea Mod. 30 siclke mower.
Length = 36"
Width = 1 1/8"
Height = 1 1/2"
Holes (rotator end) = 4 @ 5/16", centered height wise, space 1 1/2" apart, starting 13/16" (center 1st hole) from end.
Slot (rotator end) = cut top to bottom 7 1/8" long, 1/16" wide, centered front to back.
Holes (sickle end) = 4 @ 5/16", centered height wise, spaced 1 1/2" apart, starting 1 11/16" (center 1st hole) from end.
Spring for latch (sickle end) = 11/16" round, 1 1/4 deep
Chris
08-05-2002 14:31:46
 Re: Chris, NI Pitman dimensions in reply to Errin OH, 08-05-2002 09:03:36
Thanks. On my mower i went to tsc and bought a 251 pitman. it was correct and instead of the spring type latch on an ih of ford mine has one with a 6point half inch slot and you put a bolt in it and turn, thanks
