Harvesting sweet corn
Lon
08-08-2002 18:05:12
I'm looking into the economics of market gardening sweet corn for next year. I'm in the midwest (Missouri). It appears that pickup loads of sweet corn literally disappear by mid-morning at some of the many suburban farmers markets during July. Going price appears to be about $4 per dozen. It appears that demand exceeds supply. Seems like an acre or two might be a nice investment. Anybody have experience with mechanical picking? Does a one-row picker work or will it damage the ears? What brand or type of picker would be best? Comments appreciated, especially regarding the economics/feasability. Thanks.
JK-NY
08-09-2002 19:03:51
 Re: Harvesting sweet corn in reply to Lon, 08-08-2002 18:05:12
You can't pick sweet corn with a regular corn picker unless you want to corner the market on cream style corn. For a small acreage you should figure on hand picking. I grew a few acres of fresh market sweet corn for several years adnd never had a problem doing the picking alone . Nothing like going out in the morning to pick sweet corn and coming out soaked from the dew.The other posts had good suggestions, stagger plantings/maturitys, start small, plan on sprayng for bugs or throwing alot of corn to the cows. People today have no tolerance for worms in corn
JK-NY
08-09-2002 19:02:37
paul
08-09-2002 10:57:02
Pickers just beat up the corn. You can't use any old corn picker, need the right stripper plates & obviously no husking bed. Even then, I hear the corn gets pretty beat up. Sweet corn is $2 - $2.50 here in southern MN.
--->Paul
Slim
08-08-2002 19:27:09
You would need alot of acres to justify the price of a sweet corn picker because they are quite expensive. I grow 25 acres of corn a year and its all hand picked. On a few acres picking it by hand should be an easy task. Just stagger your plantings so you have a supply of corn coming on each week and don't have it all coming on at once.You will also need some kind of a sprayer to spray the corn when its silking or you will have a worm problem. Maybe you could start out with a few acres and get bigger as you go.
Brian Schmidt
08-11-2002 16:25:41
 Re: Re: Harvesting sweet corn in reply to Slim, 08-08-2002 19:27:09
What chemical should you spray with to control the worms. Have had much problems in the past with small patches. Never knew what to spray on.
Thanks.
