Bolts for plow service manual for 420s jd
cindy henshaw
08-10-2002 09:31:46
I need bolts for a 2 bottom jd plow. Its a jd623.
If anyone knows where I can get them I would appreciate an e-mail. I also am looking for a service manual for a 420s jd tractor. thanks
Bob Collins
08-11-2002 14:56:59
 Re: bolts for plow service manual for 420s jd in reply to cindy henshaw, 08-10-2002 09:31:46
Cindy, There are LOTS of bolts on the plow you have. If the 623 you gave is the beam number, it is likely a 4B plow, you can get bolts from a John Deere dealer or a hardware store etc. If you need the bolts with the funny head to hold moldboard and share parts to the frog, they also are available from farm supply stores and are called "plow bolts" Service manual for a 420 tractor is SM2019 and available from JD Publications at 800 522-7448. NOTE that is the 420 tractor built in the mid 1950s not the more recent lawn and garden tractor by the same model number.
