Dearborn 19-31 on 8N
George
08-23-2002 10:43:11
I just bought a Dearborn 19-31 loader which will go on my '48-8N. Can someone supply a photo (or explanation) of how it mounts on the rear axle. I may be missing some brackets. Also, this loader has a -31 bucket. Anyone know how this optional bucket's hydaulic cylinder mounted on the loader's frame?
Paul R.
08-24-2002 06:36:11
 Re: Dearborn 19-31 on 8N in reply to George, 08-23-2002 10:43:11
Go over to the Ford 8N board and post a message for a gentleman named Ed Gooding. He's been an endless fountain of good info for old implements. If anyone had your info, he does.
Bill
08-23-2002 19:11:26
Id be amazed if the bucket dumped with a hydroli c ylendar, if that is what you mean rather thn the cylendars used to raise it. The buckets I always saw just had a trip lever to a braket that lockled hold of a peg. When you pui;lled the lever it raised the braket of the peg and the bucket dumped
George
08-29-2002 07:29:44
 Re: Re: Dearborn 19-31 on 8N in reply to Bill, 08-23-2002 19:11:26
Bill - you're right, most Dearborn loaders used a trip bucket. Mine is set up that way too but, the bucket is an optional -31 model. Unlike the -21 and -22 standard buckets, the Model 31 bucket has a bracket off the side that allowed it to be retrofitted with a dump cylinder. I'm considering doing this but, I'm not sure where the cylinder would be mounted on the loader frame.
