Grain Auger size to fill grain bin
Ken
08-24-2002 18:29:06
Does anyone know the length of grain auger I will need to use on a grain bin that is 30ft. in diameter and has a 16.5ft. side wall. I don't know the height of the roof on the bin. Will a 8" or 10" auger work OK? The bin is a Chief brand.
Rick
08-25-2002 06:39:09
 Re: Grain Auger size to fill grain bin in reply to Ken, 08-24-2002 18:29:06
I have a Westfield brand auger 8inch diameter 61 ft long will work just fine for you if interested. This one is hydraulic lift.
Rick
08-25-2002 06:36:37
paul
08-24-2002 21:48:33
Here's a couple sites that should help, depending on your appliction. A wild guess from the charts looks like 50' barely gets by, probably be happier with more. Auger diameter depends on how fast you want to unload...
--->Paul
Link
%20Length.html
Link
Old Iron
08-24-2002 19:30:49
Ken,
The main consideration in the auger should be how high the bin is. The diameter doesn't really matter. The diameter only determines the rate of flow into the bin. The larger the diameter, the faster you will fill the bin and off-load the wagon.
My 2 bits worth,
Old Iron
