Cutter for F-20
Tony
08-26-2002 18:46:55
I am in the market now or in the spring ($) for a rotary cuter for my F-20. I will obviously need a pull type, but beyond that I don't know what specifications to look for. What can an F-20 handle? It seems many cutters are rated for something like 540 or 1000 RPM. Many give gear box ratings like 120HP. The F-20 at best is 23HP PTO, I believe. How big would be too big?
Also, how good would a used Servis be? It needs a new main seal. Any guess on how much cost and effort that would take?
Thanks,
Tony
Leroy
08-27-2002 19:10:23
 Re: Cutter for F-20 in reply to Tony, 08-26-2002 18:46:55
Your problem will be with the PTO, was not a standard size shaft, you will need the orignal IHC made PTO adapter conversion kit if you do not have it, will be hard to find
Tony
08-27-2002 19:21:33
 Re: Re: Cutter for F-20 in reply to Leroy, 08-27-2002 19:10:23
Is this the same as the PTO extension?
Leroy
08-28-2002 05:49:46
 Re: Re: Re: Cutter for F-20 in reply to Tony, 08-27-2002 19:21:33
I think that it is, I just know that a lot of F20's have just the end of the PTO up under the differential, Just make sure that you have standard size, 1 3/8", shaft and 14" between end of shaft and hitch pin, you need a hitch plate to bolt to the standard wide drawbar to set the turning point back a bit further so that the drawbar and the mower have turning room without binding and breaking something.
Leroy
08-28-2002 05:48:44
Tony
08-28-2002 10:16:33
 Re: Re: Re: Re: Cutter for F-20 in reply to Leroy, 08-28-2002 05:48:44
Thanks!
So, since the extension brings the shaft back behind the draw bar by an inch or two, I will need something 15-16" long to serve as a hitch plate? Any suggestions on what to use or is this a TSC type item?
Tony
08-28-2002 10:14:11
Thanks!
Bill
08-26-2002 22:24:08
Your F-20 will have more than 23 hp. Thats arund the range of the Regular Farmall, not the F-20. I have had 3 f-20 s in my life 55 and have a F-30 now. Your F-20 will run around 27hp or a bit mnore or less determining on the condition. You can pull a 5ft brush hog with ease with one. Keep the blades sharp and you probably can pull a 6ft. Watch those automatic turning brakes with your thumbs wrapped around the sterring wheel. Good luck
