605F Vermeer baler tie arm
paul
08-31-2002 15:29:27
I just bought a 605F Vermeer round baler. Hydraulic tie arm, and I can't get the darn tie arm to go down to start tying. It will push up if I pull it down by hand, & it makes minor jerks downward, but nothing I would consider worthwhile, never got farther to the right than 1/2 way... Played with the speed knob, and sanded/oiled the slider so it was smoother. No go. Any ideas? Manual says it limits at 600 lbs pressure, so a low power system...
On the plus side, did a real nice job making the bale - just kinda loose without the twine. :)
--->Paul
Pete in Ks
09-04-2002 06:35:25
 Re: 605F Vermeer baler tie arm in reply to paul, 08-31-2002 15:29:27
Your problem could be one of two things. First the rod and tube wear and at a point start to bind. Second this is an area that gets a lot of dirt. If oiled this becomes a thick/sticky sludge causing the rod to stick. I remove the rod and tube and clean with solvent and a long bottle brush. Then lube with a silicon spray. This will cure the problem 9 of 10 times.
KEN C.
09-01-2002 19:33:55
I HAD PROBLEMS WITH MINE AND IT WAS THE TIP ON ONE OF HOSES WHERE IT PLUGS INTO TRACTOR. NEW TIP AND WORKED FINE.DON'T COST MUCH TO TRY IT. KEN
paul
09-01-2002 22:30:01
 Re: Re: 605F Vermeer baler tie arm in reply to KEN C., 09-01-2002 19:33:55
I'll try that, no one had what I needed in stock so I had to remove from other implements, now take another off! Dern holiday weekends.... ;) I swapped outlet pairs, as well as flipped them, never have gotten that arm to swing left. Works good to extend it across so I got a few bales made, but have to push the arm down by hand to start.
Otherwise, wondering about that 600lb pressure relief valve, about all that could be wrong...???
--->Paul
KEN C.
09-02-2002 19:31:19
 Re: Re: Re: 605F Vermeer baler tie arm in reply to paul, 09-01-2002 22:30:01
Very well could be in the pressure, could be a peice of trash in the orvice.Wonder if o ring in the cylinder is bad and the oil is going by and pushing the wrong way. My arm swings down pretty fast but comes up slow, which is adjustable, but you can here the oil pressure bleeding through the regulator valve. Just some thoughts.ken
