Flat drive belts
willyz
09-01-2002 03:53:44
I need a source for flat drive belts about 8" wide to power off the pulley on my John Deere A. Thanks
Leroy
09-02-2002 19:12:23
 Re: Flat drive belts in reply to willyz, 09-01-2002 03:53:44
6" is the standard size belt that you need, 8" is for the steem engines, to wide for the tractor pullys
ih_bug
09-01-2002 20:09:47
round baler belting is fine and will take the torque . we are using it on a ih 503 combine as the main thresher drive and its on its second year taking around a 100hp.
ih_bug
09-01-2002 20:08:46
Richard
09-01-2002 16:36:59
Bamco belting in Greenville, SC makes any belt you want, even leather. Also, Meadows Co. in North Carolina sells belts. They both have web sites. Use your search engine or email me for addresses or phone numbers.
jim
09-01-2002 17:18:06
 Re: Re: Flat drive belts in reply to Richard, 09-01-2002 16:36:59
Use Richard's advice and deal with the proper suppliers. Definately do not use round-baler belting as it is designed only to form the bales and will not take the torque required with drive belts to drive machinery. You could wind up seriously hurt using anything less.
marlowe
09-01-2002 14:09:01
go to your local farm supple store and get round baler belt it comes in bulk and they will cut to length comes in all kinds of widths
marlowe
09-01-2002 14:08:41
Bus Driver
09-01-2002 09:27:59
Conveyor belting of the proper thickness probably will work well. If splicing (lacing) equipment is available to you, wide conveyor belting could be cut to your width and spliced in pieces to get the length. The fewer splices, the better, but more usually will work satifactorily.
