AC baler
Dachshund
09-02-2002 18:57:07
I've been playing with the idea of getting an Alice-Chalmers baler of the "little" round bale type. Any one out there give me the good, bad, and ugly of these things before I get stupid and buy one?
Jerry A.
09-03-2002 14:04:41
 Re: AC baler in reply to Dachshund, 09-02-2002 18:57:07
My uncle used to bale a lot with them. Very popular type baler for an early baler.
I think most parts come from graveyards, but I still see some folks in Western Illinois baling with them.
They are not as convenient as the square baler because you do indeed have to stop each time a bale ties and is kicked out of the baler.
I personally like to handle the small rounds a lot better than squares because the hay hook stays in the very bale very well. The bales tend to be a little lighter, also.
They come cheap around western Illinois. Probably get one for $100-200 or less. My uncle's old one sold for less than $75 at auction about a year ago.
Jerry (AL)
09-03-2002 13:14:32
I worked with these quite a bit in my younger days. I liked the small bales because we baled hay near the mountains on the end of the Applachians and we found several bad snakes. I always liked to kick those bales over and then pick them up.
The thing I remember was it seemed to break chains quite frequently and you did have to stop the baler while it wrapped the twine around the bale and discharged it. If you didn't get the clutch in quick enough, you broke a chain.
I also remember they were quite dangerous. The fellow that worked the farm I helped out on ultimately had his arm jerked out of the socket and almost bled to death working with the baler alone one day.
Mike (WA)
09-03-2002 12:07:26
I do remember my uncle filled the loft of his barn with them one time, stacked like cordwood, and the stack gave way a few days later and pushed both sides of the barn out.
Yeah,
09-04-2002 18:15:42
 Re: Re: AC baler in reply to Mike (WA), 09-03-2002 12:07:26
Right!
James
09-02-2002 19:24:18
I'm too young to have ever seen one work, but I've heard you have to stop and let every bale out. It would take forever compared to a square baler to make hay.
chuck
09-02-2002 19:14:27
I think that they are great, the down side is they tend to be tempermental. the only downside to me, might be that the bales must be unrolled if you don't need to feed the whole bale. They may be left in field and rained upon without major damage,the outside 1-2 inch may be lost to weather. The bales don't stack like a square bale but generally don't weigh over 40 lbs. Good condition roto balers can be bought easily in central MO for $600 and often less at farm auctions. Don't try to bale wet or green hay, they won't discharge easily.
Good luck
elaine
09-10-2002 15:37:30
 Re: Re: AC baler in reply to chuck, 09-02-2002 19:14:27
greetings in the Lord. I use the allis chalmers little round baler and think the world of it. you can bale on your own and leave them lay without worry about rain. I bale in third gear and would love to be in a race with a square baler. they can bale wetter than square bale and still dry well. there is adjustments for weight and tightness which is an added plus since I am a woman and can't lift as much. they are easy to stack and if you criss-cross them you will never have trouble with your stack. they run forever with miminal repairs. I have been home for 11 years caring for my mom with a stoke and my elderly dad who will have his 83rd birthday this month. my baler is a great blessing to me. the only downside would be not so many passes thru the field because you usually put two to four rows together depending on the size of the hay. hope you can purchase one. they are great.
