Covington rotary cutter Driveline Repair
JP(VA)
09-03-2002 10:23:54
The drive line on my rotary cutter has been sheared about 8 inches from where the inner square shaft slides in. About a inch on each side of the shear(break) is damaged. Can the damaged area be cut off and then the driveline welded together without any problems? The drive line is plenty long enough for my tractor and being shortened by a couple of inches really wont be a problem. But will it work ok?
