Hi all,As part of a package deal. I now am the owner of some hay related implements I may try to use or try to sell if they have much value. The two items I can detail right now are a New Holland 66 baler w/o the engine that was in use until last year (the gentlemen was seling off all his equipment that was usd on his 5-10 acres). Seems to be in decent shape. From what he says, it should just need a couple shear pins and either the engine or the PTO shaft to run it off a tractor. The other item it a McCormick Deering #7 mower that is missing the seat. All else at first glance seems to be there, but I plan to get a manual to make sure. There are 2 other items, one item sort of like a disc but not that I cannot recall the name of right now and a hay rake probably near the same vintage as the mower and also on steel wheels. If anyone has any comments about the posible value of these in present shape (or in fully working order) I would appreciate it. If I were to play with implements much, I might prefer to find an old corn planter to pull behind my F-20's. Bt I have 2-3 acres of former hay/now weeds I could play with and perhaps go fill hay next year. I would probably prefer to sell though if they have value, as I also need a cheap pull tye bush hog. Thanks, Tony
