Disc plow, type/value.
Steve Callahan
09-06-2002 11:21:47
I had bought a 1949 F-Cub. With it was (what I gather from looking at the implement picture section) an A-147 Cub Disc/Plow. It has the mounts that hook up to the Cub axles. Has I-beam as the front section of the frame and the rear section is very heavy cast iron. The rear wheel turns (left/right) and has linkage that extends to the tractor front spindles. The rear wheel has a lever for adjusting hieght. The numbers I found were; on the cast iron rear frame section=IH 512117R1. Disc bearing block=512141R1 and disc blade=CP6231. I hope I have described this properly. I am looking for the correct identification and the sale value of the disc/plow. Any help appreciated. Thanks. Steve.
Steve Callahan
09-06-2002 11:25:17
 Re: Disc plow, type/value. in reply to Steve Callahan, 09-06-2002 11:21:47
OOPS! Sorry for the double post.
