IH 241 Baler
joe
09-07-2002 07:15:41
I need to know about this baler, i have found one only baled 600 bales always barned. But what can you tell me about the rope to drive needles when tying? And can it be converted to hydraulic tie? Thanks in advance.
Big Jim
09-09-2002 14:44:11
 Re: IH 241 Baler in reply to joe, 09-07-2002 07:15:41
RUN.... Don't walk!!! I don't care how good it looks. Worst piece of **** ever made for a round baler. I'm speaking from personal experience.
KEN C.
09-07-2002 19:14:04
I had one,tried two years to bale with it, finally gave it away.Will not start rolling unless every thing is perfect, and that don't happen in the hay feild.Don't know if it can be changed to a cylinder or not.My two cents worth is look for something else.
Been there Done that!
09-07-2002 16:32:52
Run the other way as fast as you can. But if you must buy it, be sure to keep check on all bearings. When they go out, and they will, they will catch on fire. Pull rope till string starts to wrap, (you will need to be feeding hay in, to get it to start wrapping the string) and keep pulling till string is at the far side of the bale, let it wrap about 5 wraps, release rope a little, count to 5, release rope a little, etc. when string gets all the way across the bale, let it wrap about 5 wraps then pull roap and let go. Maybe the string will cut.
