Hay rake problems
Jim E
09-08-2002 15:21:02
I have an OLD Case 4 wheel (steel), 4 bar pull type rake. I think the problem is in the gear box. When I rake on the side of a hill with the weight pushing into the gear box it works decent. When I return heading the opposite direction it seems like the gears aren't engaging, or a safety slipping working too well. I have also tried to raise the height of the rake to keep it from digging into the grass to help keep the resistance down but that doesn't work either. Suggestions?
WILL
09-16-2002 13:59:03
 Re: Hay rake problems in reply to Jim E, 09-08-2002 15:21:02
GEAR BOX
WILL
09-16-2002 13:58:49
GEAR BOX
Jerry A.
09-09-2002 10:06:16
Sounds like some shims are in order inside the gearbox. There has probably developed too much play in the input or output shafts. A decent machine shop ought to be able to help you out with that problem.
