Help with removal of pitman weight on JD #5
Bob G
09-08-2002 17:00:28
I need to remove that counter weight that the pitman arm hooks to on my #5. So that I can stop a leak of gear lube. What is the procedure for removal.
Thanks,
Bob
Steven M
09-08-2002 17:22:52
 Re: Help with removal of pitman weight on JD #5 in reply to Bob G, 09-08-2002 17:00:28
I just used a good 3 jaw puller, and pulled it off. The key holds it on the shaft. In my case the key come off with the pitman flywheel.
