3 bottom out of a 4 bottom?
John
09-09-2002 18:52:08
Can you make a 3 bottom plow out of an IH 4 bottom and have it still work well? Any info would be appreciated.
Bill
09-14-2002 04:24:56
 Re: 3 bottom out of a 4 bottom? in reply to John, 09-09-2002 18:52:08
I made a 2 bottom out of a 3 bottom Case and it works great
T.J.-N.J.
09-10-2002 17:05:16
I am thinking about doing this with an old Cockshutt 3 bottom disk trip lift plow it almost seems like it is modular the way it was built . The neighbor said it was all the super M could do to pull it as a 3 bottom but he said nothing could get the roots of briars up to the surface after bush hogging them like the disk plow did . I figure it would be a good workout for the Ca this spring if the Mrs. will let me get her finished up and out in the field again. Somehow she always seems to always find another use for the tractor fund. T.J.
Jerry (AL)
09-10-2002 12:44:46
Did it with a JD plow.
It seems to work better, pull better, etc. without the last bottom than it did with it.
dab
09-10-2002 08:03:40
I did it with a Pittsburg (Case) 3pt. and it works great.
Jim T
09-09-2002 20:07:31
John, some #16 plows were made to delete a bottom or ADD a bottom. Not ALL 16's are this way. If you have a #16, look where the "land" wheel is on the left side as you stand behind the plow. IF the wheel is outside a STRAIGHT frame, you can't, but if the left wheel is tucked in front of the fourth bottom and the frame for the fourth bottom looks "added on" then yes you can take that bottom off and move the tail wheel up behind the third bottom. The "spine" of the plow will stick out quite a bit, or it may be cut off if you NEVER want to make it back into a 4 bottom. You will also need to adjust your hitch to get it to pull straight. Good luck. Jim T
Jim T
09-09-2002 20:04:28
