IHC Implements
Tony in Michiga
09-12-2002 19:47:18
Hello all,
I recently picked up three old IHC implements, a 2 bottom pull-type plow (Little Genius???), a soil pulverisor and a #7 mower. I would like to dat all three and get restoration info on at least the plow. Where should I look for numbers and once I have them, where do I go to see just what the plow is? I wnt to keep it and restore it into a nice looking working plow. I currently have a JD plow, but this matches my F-20 better, so if it works fine I will probably get rid ofthe JD plow.
Also, is there any reason I should not give the soil pulverizer away? Does it have value or will I be able to use it? The only plowing I intend to do is my wife's garden and perhaps a small amount of corn if I can find a corn planer of similar vintage. Basically just to play. I do not have discs unfortunately. Should I save the pulverizer to help ith breaking the clumps?
Thanks,
Tony
