530 JD round baler
john2510-3020
09-14-2002 07:16:18
Hi Guys! I just bought a different tractor about 3 weeks ago and am now looking for a baler. I would like to hear your comments on a JD 530 roundbaler with monitor. I called the guy on it this morning, he said he bought it up north, around northern missouri. He said paint is good on it etc. It is the twine tie (i was looking for a net wrap, but at this price i think i can live.) He saids in real good shape, He wants 5500 for it has the monitor and all. Is that to much? I have a 2555 that i bought, they put it on the dyno up here at the local deere dealer and they said it dynoed at 82 hp. I guess this is adequite enought for the baler? The 2555 has cab air/heat so i cant wait to start baleing with it!! Thanks for the help guys. TTYL
john
A Man
09-15-2002 06:26:09
 Re: 530 JD round baler in reply to john2510-3020, 09-14-2002 07:16:18
The guy that does my hay that is the same tractor he uses and same baler and he bales around 5000 bales a year with no trouble but the ac in those tractor are some a problems we had one and it was hard to keep cooling and with a cab in sw ok that is a must good luck and let me know how you are coming along.
Aggie
09-14-2002 09:35:12
The 530 Deere roller is the best older roller that you can buy. The price sounds great! Your tractor may lug down a little bit going up a hill when pulling the roller but at 82 hp it should do the job. I do custom rolling with a 7410 John Deere and a 535 roller.
Jim B
09-15-2002 05:29:46
 Re: Re: 530 JD round baler in reply to Aggie, 09-14-2002 09:35:12
If you bale at maximum hyd. pressure on baler and full size(6 ft. tall)bales you are going to have problems with a JD2555 because that is way above JD's advertised HP.I custom bale with a JD 4255(120 advertised HP) and a JD 467 baler at full pressure and every once in a while I can hear governor open.Two variables are ground speed and size of windrow.I bale 5-6 mph depending on ground.Jim B
