Hi Frenchy: We've all got our preferences and predjudices, but I think in general you want something you can easily take care of and which will be generally useful. So that means you should start looking at whatever brand is most prevalent in your area--whether it is Fords, or J Deeres, Farmalls or whatever. That will give you a local source of help, and probably parts. Also get a brand/model which there are a lot of built, which ensures that new or aftermarket parts are readily available and cheap...parts availability is the biggest drawback to getting an 'orphan' tractor, although if you are really dedicated and have your own machine shop you can do it. As far as features go, I'd suggest a standard category 1 3 point hitch, PTO ("live" is better, but not essential), and at least 25 horses to do much useful work. Beware of newly-painted machines! Many of these have had problems painted over, and once they run a few hours, the problems become apparent (and usually costly). On the other hand, you're a mechanic so don't shy away from one that isn't running well: mine didn't, but it only took me some hours, stretched over about 6 months that I was working her, to get her running like new (for example, the carb had been reassembled wrong! Ran ok, but I got double the power once I put it together right). Anyway, I have a Ford 8N and love it and would heartily suggest it as a good first tractor. It is rugged, parts are available all over, the 2N-8N board here on this site is the best for getting help and expertise. The *only* drawback is that the PTO isn't "live" but I've learned to work without it. good luck, Tom A
