Bearing number on JD #5 sickle mower
Bob G
09-17-2002 08:00:15
Does someone have a bearing number for the bearing on the pitman arm? The one that was in mine is bad so I removed it. There was a shim on the shaft and I want to get the right one.
Thanks,
Bob G
Hank
09-18-2002 16:39:17
 Re: Bearing number on JD #5 sickle mower in reply to Bob G, 09-17-2002 08:00:15
The part is available through your John Deere dealer. I do not remember the part number but bought one this spring from JD.
Mark
09-17-2002 10:37:56
Bob,
Do you have the needle bearing or the bushing type?
Bob G
09-17-2002 14:51:50
 Re: Re: Bearing number on JD #5 sickle mower in reply to Mark, 09-17-2002 10:37:56
I have the bushing type.
thanks,
bob
Mark
09-17-2002 19:18:32
 Re: Re: Re: Bearing number on JD #5 sickle mower in reply to Bob G, 09-17-2002 14:51:50
Bob,
I don't have a #5 parts book but I believe that I bought a new bushing at the JD dealer, it was still available. Was at a tractor junkyard this summer and saw a pitman arm with the bearing. I bought it but haven't put it on yet. I've been thinking of making my own bearing flange and installing a sealed bearing that wouldn't have to be lubed.
Good luck,
Mark
