Disk level
Dale (MI)
09-24-2002 14:51:08
I got an old 10 foot disk harrow, probably an IHC. The front row of disks cut in pretty good but the back is hardly touching the ground. There is a frozen crank above and behind the hitch and I wonder if that is supposed to adjust the hitch
height and help lower the back. I also am going
to try lowering the hitch to another set of bolt holes. Any suggestions?
Thanks - Dale(MI)
09-27-2002 13:15:38
 Re: disk level in reply to Dale (MI), 09-24-2002 14:51:08
I managed to turn that crank one turn with a pipe wrench and that seemed to help. I am going to work on it some more. Thanks for your tips.
Bill Becker
09-26-2002 06:21:38
The crank you described on the hitch is used to level the disk. You will need to loosen it up in order to get the disk to work right. The front gangs will do the majority of the cutting. The rear gangs are used primarily for leveling.
Sid
09-24-2002 19:54:19
Dale what you have described does sound like the adjustment you want.
Sid
09-24-2002 19:53:39
