Chisel plow
randy
04-19-1999 04:23:29
what is a chisel plow??
Aaron
04-19-1999 15:01:36
 Re: chisel plow in reply to randy , 04-19-1999 04:23:29
It is a primary tillage tool. If you know what a field cultivator is, or know what a row crop cultivator is, it is essentially a heavier version of a field cultivator. They use a heavy shank with some kind of spring for rock protection. The shanks are placed every 12 to 18" on 3 or 4 bars. They tend to be about 12 to 15' wide. try the web site I think I put in. There are some good pictures of modern farm equipment. Older stuff is essentially the same thing, only smaller. For those of you who are partial to other colors, they have web sites too.
Aaron
LB
04-21-1999 05:24:50
 Re: Re: chisel plow in reply to Aaron, 04-19-1999 15:01:36
How well does the chisel plow work in an old hay field for a corn crop? I bought a 13shank chisel cheap and thought I would try it out. Will I have to disc alot afterwards? Thank you in advance.
Miles
04-21-1999 09:24:57
 Re: Re: Re: chisel plow in reply to LB, 04-21-1999 05:24:50
Can put sweeps on it and get a partial kill. either spray it with Round Up first and then disc or moldboard it.
