Hot Dang ! Give that redneck plow some rein and let 'er rip!
ShepFL
09-30-2002 07:16:55
Thanks to all for your assistance!
This past weekend I dropped the chains, raised the RH lift arm another 1", lowered rear of plow 6" from level.
Drove to the field and made some tweaks and raised plow so it leans back ~4". This things runs fine now. No more jerking and cuts pretty as you pls. Couple of times got a little to deep (12") as position control wing nut vibrated loose. Thats when the ol' governor kicked in. Tell ya what! That ol' Oliver will pull the bottom out of sink hole! Except of course when I decide to bury it in wet muck.
Got most of one field plowed 20 acres then I jambed the only stick in the whole field into the radiator. Sprang a small leak in lower 1/3 of radiator. Got to get out some JB Weld or QuickSteel to mend it then get this job finished. Thanks again!
I will try to post some pics of rig in action this coming weekend if any interest.
Grins from FL :)
ShepFL
