Farmall C with mounted plow
NavistarRV
09-30-2002 11:33:36
I'm looking for a diagram or photo of a C with the one bottom plow attached. Ours appears to attach newr the bellhousing with sopme plates. But what lifting mechanism is used. DO we need the rod that goes near your left leg back to a rock shaft? (We have neither on our C)
thanks for all the help on these forums.
DaveK(IN)
10-01-2002 17:46:35
 Re: Farmall C with mounted plow in reply to NavistarRV, 09-30-2002 11:33:36
I have a C with a mounted plow but it is two bottom. The plow is actually pulled from a bracked that attaches to the tractor near the bell housing. One rockshaft of the touch control goes down to control the plow angle/depth. The other rockshaft lifts the plow from the rear of the tractor. This is done with a connecting rod that goes past the driver to a lifting mechanisim attached to the rear axel. I am sure somebody on this site has a picture. If not, I can take one and send it but it will be a while. We aren't digital yet.
DaveK(IN)
10-01-2002 17:45:14
