Dearborn sickle bar mower model 14-15
boomer
10-01-2002 17:36:48
I was searching for any photos or information on
this mower. It is designed to hook to my Fergison
TO-30 tractor or other three point set ups,thanks.
Leroy
10-02-2002 16:57:25
 Re: Dearborn sickle bar mower model 14-15 in reply to boomer, 10-01-2002 17:36:48
A few year ago when I got mine Ford could not provide a manual or any parts, since then I have aquired a manual, Off Ebay I think, I have since provided several people with photo copies, have one to get done and out now, I have a lot of the manuals that are not avaible from N-News, Leroy
Paul R.
10-02-2002 07:40:32
You're in luck. Goto the Ford 9/2/8N discussion board, do a site search for "ED GOODING" and/or "DEARBORN MOWER". Ed has posted lots of scans right out of the manual, you'll probably get everything you want right there.
A caveat: the Dearborn 14-15 could be a bear to attach, you needed to remove sone of the standard 3-point links and install special pieces on the tractor in their place. If you don't have all the right pieces, you'll have a tough time getting it to work right. Good luck.
Tom A
10-02-2002 04:26:47
New Holland still sells many parts and reprints of the manual for it. I haven't bought one for the 14-15, but most old manuals I've bought from them have run me about $7-$15. They've got an 800 number to order:
800-635-4913 It operates 8-4, Monday-Friday.
Some of the parts are inexpensive, some will be pricey.
good luck,
Tom
Scott
10-01-2002 18:02:14
Yes it will work if you have all the attaching parts that people usually left on the tractor or put on a shelf it their shed when they quit using the mower, N-news.com should have a manual listed you can buy that shows the attaching parts required, sometimes they can be found on Ebay.
